Brass key 13/22 flat style $6,
Data plate mounting screws 4/40 cents,
frt. spindle washers $2,
brake rod clevis pin standard 12/27 4/80 cents
starter motor mounting screw set $ 2.50
rear fender bracket to frame bolt set $15
front fender bracket to frame bolt set $15
carb choke rod sleeve $2.75
modern inner oil seal set $20
Steering gear drive pinion & gear set 4 to 1 and 5 to 1 $56 each. all plus postage These are all new still in package
small parts SOLD
Topic author - Posts: 1198
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
small parts SOLD
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Re: small parts
Melba, suggest when you do a long list of parts like above, put each part and price on its own line. You might click on the edit icon, the pencil, and try it on this one. You don't need to put your email address in the post. All someone has to do is click on the 3 dots after Contacts, a drop down will open, and they can send you an email or message via this site.
1920 Dodge touring
1920 Dodge touring
- First Name: Melba
- Last Name: Nolan
Re: small parts NOS
everything sold pending paymet
