Early oil petcock
Early oil petcock
Post by Allan » Fri Jun 24, 2022 3:38 am
This is the very early style with the screw to hold the taper rather than the later spring. I need $71 for it, posted to your door. Unfortunately, as small as it is, it has to post at the minimum parcel rate.
