Ball bearing Rear end thrust FS New Price
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat Jul 02, 2022 3:58 pm
Here is a set of aftermarket Ball Bearing Thrust bearings. They maybe NOS no sure. There 2 of the ball bearings plate and 7 of the race plates. Ran them through the vibration tumbler to remove the surface rust. Can they be used? That will be up to new owner. $20 + shipping. Email me at address in pictures. Thanks Dan
Re: Ball bearing Rear end thrust FS
Post by Allan » Sat Jul 02, 2022 10:50 pm
Dan, are the 7 solid plates different thicknesses? That would allow some adjustment within the pumpkin when assembling the diff centre. Just curious.
MTFCA Number: 14383
Post by speedytinc » Sat Jul 02, 2022 11:11 pm
They mount on the stock thrust washer pins. You can add shims to tighten the gear clearance.
If too tight, you get creative. remove material from the carrier or surface grind the race plates.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun Jul 03, 2022 4:51 am
Do not know, have not measured them. Here is copy of ad for them. Thanks to Dan T for posting it in other forum.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun Jul 10, 2022 3:41 pm
No interest in these? Off to china I guess.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri Jul 29, 2022 9:42 am
Hate to scrap
