Wanted- 32x4 clincher tire
Mike Lebsack-Iowa
Last Name: Lebsack
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Mon Jan 14, 2019 9:27 pm
I am looking for a needle in a haystack for a project I am working on. I have a 24 inch clincher rim that can take any of the 3 following size clincher tires: 32 inch x 4 inch, 815 mm x 105 mm, or 810 mm x 90 mm. This can be an older tire as long as it can be mounted and can hold air. I will use a new tube. Any help would be greatly appreciated. Thanks, Mike
