Winfield S/SR-AA carb adapters
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Jul 04, 2022 11:09 pm
Here are 2 ea. Winfield S/SR-AA to 2.375” bolt spacing 2 bolt flange (Model A) carb adapters. I make these new for the Model A guys, but found that this adapter was perfect for swapping out the U&J on my touring car (see pic below).
1 carb adapter is simple S/SR-AA to 2.375”, and the other has a built in bell crank mount. These are modified from my typical design as I needed to tap the 2 bolt flange 3/8”-16 for my application and of course the bell crank mount.
$75 each plus shipping
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Winfield S/SR-AA carb adapters
Post by Kevin Pharis » Mon Jul 04, 2022 11:10 pm
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Jul 10, 2022 11:18 am
Back to the top
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Sun Jul 10, 2022 11:58 am
Kevin, very nice. Are you using a cable to your throttle lever on the column?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Jul 10, 2022 7:46 pm
I was able to carefully bend a control rod to connect the carb. You can just barely make out the bell crank arm and control rod buried in the back of the pic above. It was no easy task!
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Sep 15, 2022 8:57 pm
Still have these carb adapters available. The original design was to adapt a Winfield AA to a Model A intake manifold, but they will fit any manifold with 2-3/8” bolt spacing. Also have size A and B adapters too…
Post by Scott_Conger » Thu Sep 15, 2022 10:09 pm
Those adapters sure look nice...do I see chromate on them? At least to me, they look like they've been tumbled and chromated.
Always a treat to see your exemplary work.
NH Full Flow Float Valves
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Thu Sep 15, 2022 11:55 pm
Thank you Scott! No chromate on these, they are tumbled in a ceramic media that does a good job of making the tooling marks disappear, while the alkaline detergent brightens em up nicely. I use this same tumbling process on most everything I make. It takes the “billet” feel out of the parts
Here is an example of one of my choke horns fresh out of the machine;
And after blending and tumbling (much better!)
Post by Scott_Conger » Fri Sep 16, 2022 9:03 am
that is a really nice look...almost lost-wax casting-ish
I'm not surprised they're not chromated...that is all but obsolete these days...nasty stuff (but it was very effective).
