I need a front hub for a T wire wheel, does not have to be serviceable, only going to make a wheel paint fixture using an old spindle.
Jerry
WTB Front hub
Topic author - Posts: 56
- First Name: Jerry M
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring1927
- MTFCA Number: 31760
- MTFCI Number: 24585
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Front hub
Might have just the one you need. Will look later.
- First Name: Jim
- Last Name: Riedy
- MTFCA Number: 25079
- MTFCI Number: 18732
Re: WTB Front hub
Jerry, I made one out of a junk front wheel drive hub from what I believe a GM product. Just went to a independent shop and asked to look at at their scrap hopper, GM 5 bolt has the same bolt pattern if I recall correctly. Then I just bolted it to a cheap engine stand head. Works good for truing and straightening also. Jim
P.S. I also drilled additional holes so I can move the studs and use it for model A wheels also.
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
Re: WTB Front hub
Have exactly what you need. Pay shipping and it's yours. ctleonard64@gmail.com
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Re: WTB Front hub
Sorry, mine was a rear hub.
- First Name: Art
- Last Name: Mirtes
- MTFCA Number: 32489
- MTFCI Number: 24068
Re: WTB Front hub
Either a front hub or rear hub should do what you want to do. The GM front brg has the splines for driving. The rear in general doesn't. NDH Division of General Motors in Sandusky made millions of these. Up to,60,000 hub bearings per day.
Art Mirtes
Art Mirtes
- Last Name: Young
Re: WTB Front hub
Found one, thanks for all your responses.Jerry
