mainbearing linebore unit
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
linebore unit for boring the mainbearings and cutting thrust surfaces on models T or A Ford mainbearings … includes 4 bearing linebore frame , boring bar and bits and radius/facing bit to cut thrust surfaces and clearance radii , false cam and locator brackets and bushings and dial indicator tool set and instructions … price $1050 plus $95 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
NEW PRICE ... this new INCREASED price reflects the current materials and shipping cost ... sadly , these cost increases and material supply issues may cause many small businesses to cease production or the supply of service ...while i do not benefit beyond the recovery of most of ,my materials cost again , i am saddened to announce this increase ,..
- First Name: Gene
- Last Name: French
Re: mainbearing linebore unit
Linebored main bearings
- First Name: Gene
- Last Name: French
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
to the top again ...Thanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Patrick
- Last Name: Goodman
- * REQUIRED* Type and Year of Model Ts owned: 1919 Runabout 1925 touring
- Board Member Since: 2022
What can be used to drive the shaft?
- First Name: Gene
- Last Name: French
Patrick:
this is driven by your 1/2" drill motor ... others have rigged an elaborate feed system by using a milling machine or lathe ... my design works well with a simple drill motor and hand feed ... boring bit is ground with a left hand lead ... this causes a slight resistance to the feed motion allowing a controllable feed ... you may call for additional info ... i will send an email with the proceedure sheets in an attachment ...Gene French 970-581-2808
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
