model T mainbearing mold
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Board Member Since: 2014
Post by Gene_French » Sun Jul 17, 2022 10:06 am
my original design Model T mainbearing mold will pour the babbitt bearings in BOTH the block and caps of the Model T Ford engine ... the bearings will be poured at 1 1/8" diameter to allow for finish machining as needed ... instructions are included as well as my phone or email support ... price is $120 plus $16.50 priority mail postage in lower 48 states ...actual postage outside this area or INTERNATIONAL ...Gene french ph. 970-581-2808 address : Gene French 49519 cr23 Nunn, Co. 80648
t main top.jpg (1.95 KiB) Viewed 2598 times
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Re: model T mainbearing mold
Post by Gene_French » Sun Jul 17, 2022 10:47 am
picture of babbitted block and caps ... my design mainbearing mold uses a single center gate (spru) ... the intent in this design is to eliminate the knit line that can occur with many of the vintage multiple gate molds ... the multiple flow front that was present with the multiple gate tools often entrapped gasses or impurities at the knit line ... the single center gate design will cause gasses or impurities to move toward the vented endcaps to avoid entrapment ...always an optimist Gene French
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sat Sep 24, 2022 11:20 am
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sat Nov 26, 2022 10:21 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sun Jan 08, 2023 9:54 am
to the top again ....thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Tue Feb 21, 2023 10:28 am
BarrettR
First Name: RogerA
Last Name: Barrett
Post by BarrettR » Wed Feb 22, 2023 2:08 pm
Had some issues with the babbit not flowing all the way to the top of the mold especially the right front corner ect. Would you suggest putting shims under the mold plate? Or inlarging the vent holes?
Last Name: Tannehill
MTFCA Number: 49460
Post by JTT3 » Wed Feb 22, 2023 2:25 pm
Your mold is not hot enough.
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Wed Feb 22, 2023 9:10 pm
exactly right Brother John ... a uniform pre-heat is very important ...
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Fri Mar 24, 2023 10:53 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sun Apr 02, 2023 11:15 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sat May 13, 2023 9:37 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sun Jul 02, 2023 10:08 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Sun Oct 01, 2023 11:25 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Fri Dec 01, 2023 10:20 pm
to the top again...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Thu Jan 18, 2024 9:59 am
Gene_French
First Name: Gene
Last Name: French
MTFCA Number: 15614
Post by Gene_French » Thu Mar 28, 2024 10:04 am
to the top again ... thanks MTFCA
