model T mainbearing mold
Posted: Sun Jul 17, 2022 10:06 am
by Gene_French
my original design Model T mainbearing mold will pour the babbitt bearings in BOTH the block and caps of the Model T Ford engine ... the bearings will be poured at 1 1/8" diameter to allow for finish machining as needed ... instructions are included as well as my phone or email support ... price is $125 plus $19.30 priority mail postage in lower 48 states ...actual postage outside this area or INTERNATIONAL ...Gene french ph. 970-581-2808 address : Gene French 49519 cr23 Nunn, Co. 80648
t main top.jpg (1.95 KiB) Viewed 12020 times
Re: model T mainbearing mold
Posted: Sun Jul 17, 2022 10:47 am
by Gene_French
picture of babbitted block and caps ... my design mainbearing mold uses a single center gate (spru) ... the intent in this design is to eliminate the knit line that can occur with many of the vintage multiple gate molds ... the multiple flow front that was present with the multiple gate tools often entrapped gasses or impurities at the knit line ... the single center gate design will cause gasses or impurities to move toward the vented endcaps to avoid entrapment ...always an optimist Gene French
Posted: Sat Sep 24, 2022 11:20 am
by Gene_French
to the top again ...thanks MTFCA
Posted: Sat Nov 26, 2022 10:21 am
by Gene_French
Posted: Sun Jan 08, 2023 9:54 am
by Gene_French
to the top again ....thanks MTFCA
Posted: Tue Feb 21, 2023 10:28 am
by Gene_French
Posted: Wed Feb 22, 2023 2:08 pm
by BarrettR
Had some issues with the babbit not flowing all the way to the top of the mold especially the right front corner ect. Would you suggest putting shims under the mold plate? Or inlarging the vent holes?
Posted: Wed Feb 22, 2023 2:25 pm
by JTT3
Your mold is not hot enough.
Posted: Wed Feb 22, 2023 9:10 pm
by Gene_French
exactly right Brother John ... a uniform pre-heat is very important ...
Posted: Fri Mar 24, 2023 10:53 am
by Gene_French
Posted: Sun Apr 02, 2023 11:15 am
by Gene_French
Posted: Sat May 13, 2023 9:37 am
by Gene_French
Posted: Sun Jul 02, 2023 10:08 am
by Gene_French
Posted: Sun Oct 01, 2023 11:25 am
by Gene_French
Posted: Fri Dec 01, 2023 10:20 pm
by Gene_French
to the top again...thanks MTFCA
Posted: Thu Jan 18, 2024 9:59 am
by Gene_French
Posted: Thu Mar 28, 2024 10:04 am
by Gene_French
to the top again ... thanks MTFCA
Posted: Sat Jun 15, 2024 10:10 am
by Gene_French
to the top again , thanks MTFCA
Posted: Sat Jul 13, 2024 9:16 am
by Gene_French
Posted: Sun Aug 04, 2024 9:09 am
by Gene_French
Posted: Thu Aug 29, 2024 9:25 am
by Gene_French
Posted: Mon Nov 04, 2024 3:01 pm
by Gene_French
Posted: Sat Jan 04, 2025 10:56 am
by Gene_French
Posted: Thu Feb 13, 2025 9:17 am
by Gene_French
will have molds and instructions on display at the Duncan,Ok. swapmeet in March ... stop in and visit and pickup tools to save on postage ...Gene French 970-581-2808 or gfrench1953@hotmail.com
Posted: Fri Apr 18, 2025 8:40 am
by Gene_French
Posted: Fri May 30, 2025 10:01 am
by Gene_French
Posted: Sat Jul 05, 2025 8:33 am
by Gene_French
Posted: Sat Nov 08, 2025 8:31 am
by Gene_French
Posted: Thu Dec 18, 2025 10:03 am
by Gene_French
Posted: Mon Dec 29, 2025 8:52 am
by Gene_French
Posted: Sat Feb 14, 2026 10:27 am
by Gene_French
