Free: Steel Truss Head Rivets 3/16" x 1 1/4"
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Fri Jul 29, 2022 10:39 am
Free: approx 4 lbs (roughly 250 - 300 pcs.) Truss head (or mushroom head or brazier head) rivets, with a 3/16" x 1 1/4" shank, made of what I'm pretty sure is mild steel. Some surface rust is present but they should clean up pretty easily. I believe these would be well-suited for riveting wood slats to a steel frame, as you would on a pickup bed or depot hack body, as long as the wood isn't too thick. You pay shipping, of course.
Also some other weird rivets I'll never use: Approx. 3000 pcs Brass semi-tubular hollow rivets, measuring 9/64" diameter and a shank lenght of 3/16. They came in a box that was labeled "34 Chevrolet" so I'm guessing these might fit on a clutch disk or brake shoe for a 1934 Chevy. You pay shipping.
And finally a bunch of small aircraft rivets, solid aluminum with flat heads for countersunk holes, surplus old stock probably ca. 1950. They measure approx. 0.095" (3/32") diameter and the overall length is 0.26", the shank length is approx 0.21". Of course it will take hundreds of these rivets to make up 1 1/2 lbs. You pay shipping.
Thanks for looking.
Richard K
Last Name: Kemp
* REQUIRED* Type and Year of Model Ts owned: 1926 TT Tow Truck
MTFCA Number: 49768
Re: Free: Steel Truss Head Rivets 3/16" x 1 1/4"
Post by Richard K » Fri Jul 29, 2022 10:52 am
Pm sent for steel rivets. Thanks Rich
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Fri Aug 05, 2022 8:52 pm
Still have plenty of rivets left. Thanks for looking!
catfishunter99
First Name: LORIEN
Last Name: HEGNER
Post by catfishunter99 » Sat Aug 06, 2022 5:11 pm
PM sent for the brass rivets
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Tue Aug 09, 2022 10:03 am
Hi Rodger,
Rivets arrived yesterday. Thank You.
Craig.
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Sun Aug 21, 2022 10:19 am
There's still plenty of the Steel Rivets left if anybody wants some of them.
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Sat Sep 17, 2022 11:00 am
I found more of these let me know if you want some thanks
Rodger Erickson
First Name: Rodger
Last Name: Erickson
MTFCA Number: 32062
Post by Rodger Erickson » Fri Nov 04, 2022 12:13 pm
Any of you guys need any more steel rivets? I've still got a bunch!
