WTB SCHRADER 2061 RIM NUTS - FIT 725 STEMS
CDooREDW
First Name: Ron
Last Name: Wenzel
* REQUIRED* Type and Year of Model Ts owned: ‘14 SWT Runabout; ‘22 Center Door
MTFCA Number: 50735
Post by CDooREDW » Mon Aug 08, 2022 9:39 pm
Looking for 3, preferably 4, nickel Schrader P/N 2061 rim nuts that fit Schrader 725 (fatter) metal stems.
Having trouble loading photos. These are the formed flat nuts with recessed rubber or leather washer in the nut recess.
Thank you. Text works at 93 one - 6 oh 7-8353
Ron Wenzel in HSV
Layden Butler
First Name: Layden
Last Name: Butler
Re: WTB SCHRADER 2061 RIM NUTS - FIT 725 STEMS
Post by Layden Butler » Tue Aug 09, 2022 1:46 pm
Do you mean 2081 as in this illustration?
CDooREDW
First Name: Ron
Last Name: Wenzel
MTFCA Number: 50735
Post by CDooREDW » Tue Aug 09, 2022 2:39 pm
Yes sir, Layden,
I’ll blame it on fat fingering. Should correctly be a no. 2081.
Also, I may actually prefer the nut which also has the conical taper to keep the stem centered in the felloe hole.
Hoping you may have several available, pls.
Thank you,
Ron in HSV
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Tue Aug 09, 2022 3:02 pm
This is the one you prefer.
CDooREDW
First Name: Ron
Last Name: Wenzel
MTFCA Number: 50735
Post by CDooREDW » Tue Aug 09, 2022 3:13 pm
Yes sir, that’s it. Do you happen to have three or four you’d like to part with?
Tnx,
Ron
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Aug 10, 2022 11:41 am
For everyone's information. Dan McEachern has exact copies of the original rim nuts for your early car. He went to a lot of trouble to make these. He is asking $20 each for them. Check the latest judging guidelines and they are mentioned as being correct for all T's up through 1916.
