Commutator rod swivel F/S
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Fri Aug 12, 2022 7:42 pm
I can supply a very limited number of the proper timer control rod swivels with nut for earlier Model Ts. They are NOS New Old Stock and there will be no more when these are gone. If you do not have a threaded rod, I will throw in ( until they run out) a later control rod that you could cut off the end and thread for the swivel. Priced at $45 each, domestic postage $10 per order. Let me know if you prefer bare iron or bright.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Commutator rod swivel F/S
Post by Kevin Pharis » Fri Aug 12, 2022 11:05 pm
I’m assuming these are #10-32 thread...? I have looked in every nook and cranny for this size, and not currently available new! This is also the typical size for most carburetor linkage as well. Thank you for making these available Layden!
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Aug 13, 2022 12:09 pm
Kevin,
NO these are the correct 12-32 OR 7/32-32.
Ford Model T catalog shows 7/32-32.
See attached info below.
Note that the 2 sizes are only 2 thousandths " different and do directly interchange.
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Mon Aug 29, 2022 3:37 pm
Don't hold out until they are sold out!
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
MTFCA Number: 21848
MTFCI Number: 22173
Post by rickd » Wed Aug 31, 2022 10:43 am
Email sent.
Modelttommy
Last Name: Helf
* REQUIRED* Type and Year of Model Ts owned: 1911 Ford Model T Touring
Post by Modelttommy » Mon Sep 12, 2022 1:40 pm
do you still have the swivel for the early model t ford spark control rod. Thanks Tom, 1911 touring
tman12
First Name: john
Last Name: Willams
* REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
MTFCI Number: 20566
Post by tman12 » Mon Sep 12, 2022 3:17 pm
Hi From Iowa! i would like one of the swivel & rod sets if available? Thanks john
