Commutator rod swivel F/S
Topic author - Posts: 1509
- First Name: Layden
- Last Name: Butler
I can supply a very limited number of the proper timer control rod swivels with nut for earlier Model Ts. They are NOS New Old Stock and there will be no more when these are gone. If you do not have a threaded rod, I will throw in ( until they run out) a later control rod that you could cut off the end and thread for the swivel. Priced at $45 each, domestic postage $10 per order. Let me know if you prefer bare iron or bright.
- First Name: Kevin
- Last Name: Pharis
Re: Commutator rod swivel F/S
I’m assuming these are #10-32 thread...? I have looked in every nook and cranny for this size, and not currently available new! This is also the typical size for most carburetor linkage as well. Thank you for making these available Layden!
- Last Name: Butler
Kevin,
NO these are the correct 12-32 OR 7/32-32.
Ford Model T catalog shows 7/32-32.
See attached info below.
Note that the 2 sizes are only 2 thousandths " different and do directly interchange.
- Last Name: Butler
Don't hold out until they are sold out!
- First Name: Rick
- Last Name: Duquette
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
- MTFCA Number: 21848
- MTFCI Number: 22173
Email sent.
- First Name: Tom
- Last Name: Helf
- * REQUIRED* Type and Year of Model Ts owned: 1911 Ford Model T Touring
do you still have the swivel for the early model t ford spark control rod. Thanks Tom, 1911 touring
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
Hi From Iowa! i would like one of the swivel & rod sets if available? Thanks john
