WTB American Bosch Distributor Parts
Posted: Sat Aug 13, 2022 7:54 am
by Bryant
I know it’s not easy but Iam looking for parts for the American Bosch distributor. Type T-448. Manly the distributor cap. Part#65942. Also any surviving information books on the distributor. Thanks
Re: WTB American Bosch Distributor Parts
Posted: Sat Aug 13, 2022 9:08 am
by Tom VanMeeteren
Bryant, see my post in the General discussion regarding these dist caps.
Posted: Sat Aug 13, 2022 12:55 pm
by Craig Leach
Hi Bryant,
I have a cap in a little better shape than the one pictured. In the past I have used the drive & adapted to a 009 Bosch distributer Then if wanted can go to Pertronics electronic ignition.
Craig.
Posted: Sat Aug 13, 2022 6:06 pm
A point you might want to think about. Most of these old units, the shaft and bushings/body are worn. With wear, you change your cylinder firing as the shaft wobbles and the air gap between the cap and rotor changes. A car putting around at 35 or less, might not be much of an issue, but ideally you want that gap to stay pretty close to the same all the time.
Posted: Mon Aug 15, 2022 8:48 pm
by SIR TIMOTHY
I have this extra sitting on a shelf. tim
Posted: Tue Aug 16, 2022 2:08 pm
Be careful. Caps for Bosch front plate distributors are not the same as caps for clip-on style distributors.
Posted: Tue Aug 16, 2022 3:04 pm
by Bryant
thanks for the heads up! I’ve been doing research till Iam blue in the face. Is this cap one for a clip on? I noticed a different part number and manufacturers logo.
Bryant
Posted: Tue Aug 16, 2022 4:14 pm
thanks for the heads up! I’ve been doing research till I am blue in the face. Is this cap one for a clip on? I noticed a different part number and manufacturers logo.
Bryant
I believe the one shown by Sir Tim is for a clip-on. Notice how yours has a "male" locating lug, versus Tim's which has a groove for location.
Posted: Thu Aug 18, 2022 3:57 pm
by Bryant
Rolling The Dice 🎲 🎲
Looking for the oil cup for the distributor shaft. Attached to the outside of distributor housing.
Bryant
Posted: Thu Aug 18, 2022 6:19 pm
It is not an "oil cup" but a "grease cup". Grease cups are designed to push grease into whatever
Posted: Thu Aug 18, 2022 7:18 pm
by Bryant
Here’s an example
I did see the clip on Bosch had the grease version. This distributor has to travel through an empty space about an inch. I think it may have had a wick. Thanks jerry for the pictures
Posted: Thu Aug 18, 2022 7:35 pm
Here's another part to look for. It's a rare find though. Hard to make it out in the photo, but the thumbnut has the "AB" American Bosch logo cast into it. Obviously not a necessity, but kinda cool if you can find one.
Posted: Fri Aug 26, 2022 7:06 pm
by Bryant
Rolling the dice 🎲 🎲
Can I get a condenser? Anyone? Don’t be shy
Posted: Fri Aug 26, 2022 7:35 pm
by J1MGOLDEN
The condenser does not have to be inside the distributor.
Follow that distributor wire to the coil and place the condenser there.
All those little round condensers with the pig tail wire are the same size as an early Ford coil condenser.
Some of the coil bands have a small area about 3/8th inch square with a tapped hole in it for a screw to hold the condenser band.
Look for one of those.
Posted: Fri Aug 26, 2022 10:43 pm
by Tom VanMeeteren
Bryant, I have them NOS contact me again Tom
Posted: Sun Aug 28, 2022 9:08 am
by Bryant
sounds good email sent
Posted: Sun Aug 28, 2022 1:21 pm
by Tom VanMeeteren
I have NOS point sets, rotors, resistance units and condensers available for the Bosch units. As mentioned before, no caps available at this time. Thinking about reproducing them, but still not enough interest. Included is pictures of the resistance unit and the condenser (if I finally got them loaded
Posted: Sun Aug 28, 2022 1:22 pm
by Tom VanMeeteren
picture of the condenser
Posted: Sun Aug 28, 2022 1:23 pm
by Tom VanMeeteren
darn condenser won't load
Posted: Sun Aug 28, 2022 10:07 pm
by Tom VanMeeteren
[image][/image]3rd try on the condenser
Posted: Mon Aug 29, 2022 7:16 pm
by Tom VanMeeteren
Condenser - try again :?:
Posted: Mon Aug 29, 2022 7:28 pm
by Bryant
Hey Tom
What’s your price on the condenser?
Bryant
Posted: Tue Apr 18, 2023 7:25 am
by Bryant
Trying to find the cam and distributor shaft gears for this unit..
Still looking for the oil cup
Bryant
Posted: Tue Apr 18, 2023 8:45 pm
Bryant
Chaffin's Garage, page 47.
A little cheaper at Lang's...
https://www.modeltford.com/item/BO2.aspx
You might need this too?
https://www.modeltford.com/item/BO-LN.aspx
Posted: Wed Apr 19, 2023 1:09 am
Hope this helps Not sure what the difference is in Models "Type FI-513" and "Type T-448"
Whats the issue with the cam?
The conversion PDF discusses some measurements and options.
Instructions & parts list FI-513.
1923boschmaginstmanual.pdf
(419.76 KiB) Downloaded 108 times
from the above
from your earlier post T-448
Points & your missing parts look the same as a Model 600
Conversion to electronic ignition
Conversion it electronis.pdf
(346.75 KiB) Downloaded 98 times
Posted: Wed Apr 19, 2023 2:01 pm
by Paul-Geil
Bryant, I have this Bosch distributor that I removed from a running T. If you’re interested, let me know.
Posted: Wed Apr 19, 2023 6:01 pm
by Bryant
Thanks Jerry! I think I’ve seen those before but wasn’t clear if they where for my distributor.
Thanks Frank for all the good info! The gears I have look to be repaired and I don’t think I will trust them.
Paul I sent you a email
Bryant
