Any one have any inner tube stems?
or had success at vulcanigaing replacement rubber stems.
Rich 561 262 o393
inner tube stem
- First Name: Tom
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1921 Speedster 1927 speedster
- MTFCA Number: 9495
- MTFCI Number: 9495
- Board Member Since: 2013
Re: inner tube stem
Rich:
I have a inner tube stem and a tube, A 21inch tube that I want to sell. The stem needs to be vulcanized to the tube or a tube of your choice. Tom 503- 644-937four
Topic author - Posts: 362
- First Name: Rich
- Last Name: Jesteadt
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1913 Touring project w. "A" crank shaft
- MTFCA Number: 50484
- MTFCI Number: 24737
Re: inner tube stem
I'm looking for proper length stems or source for them.
- MTFCA Number: 121
- MTFCI Number: 16310
Re: inner tube stem
How can you be looking for an inner tube stem, when you don't even know the size of the tire?
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
Re: inner tube stem
I don't have any to spare, but I suspect the stems you are looking for are Schrader 777. Schrader 888s will also work, they are 1/4 inch shorter than 777 and therefore take a 1/4 inch shorter dust cap.
- Attachments
- schrader_777_stem_hardware.jpg (29.35 KiB) Viewed 765 times
- First Name: Rich
Re: inner tube stem
Original Smith wrote: ↑Sun Aug 14, 2022 10:09 amHow can you be looking for an inner tube stem, when you don't even know the size of the tire?
evidently Toooo many beers again ?
