Need the drive gear for a Texas t distributor missing one.
Thanks,
Brian Jordan
Texas t distributor drive gear
Topic author - Posts: 38
- First Name: Brian
- Last Name: Jordan
- * REQUIRED* Type and Year of Model Ts owned: 1926 roadster pu , 14 touring
- MTFCA Number: 424
- Last Name: Hjortnaes
- MTFCA Number: 28762
- MTFCI Number: 22402
Re: Texas t distributor drive gear
Did you try Birdhaven?
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Does anyone know the # of teeth & diameter of the gear? some times these are copied from other distributors and the gears may interchange. It looks like most gears are cut the opposite direction from the Texas T distributor. The pics on the internet indicate it is similar to a Thomas?
Craig.
Craig.
