Texas t distributor drive gear
W Brian Jordan
First Name: Brian
Last Name: Jordan
* REQUIRED* Type and Year of Model Ts owned: 1926 roadster pu , 14 touring
MTFCA Number: 424
Post by W Brian Jordan » Thu Aug 18, 2022 8:53 pm
Need the drive gear for a Texas t distributor missing one.
Thanks,
Brian Jordan
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Re: Texas t distributor drive gear
Post by DHort » Thu Aug 18, 2022 10:26 pm
Did you try Birdhaven?
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Mon Aug 22, 2022 10:55 pm
Does anyone know the # of teeth & diameter of the gear? some times these are copied from other distributors and the gears may interchange. It looks like most gears are cut the opposite direction from the Texas T distributor. The pics on the internet indicate it is similar to a Thomas?
