Packing the truck for Hershey, RCC 33&34
Topic author - Posts: 105
- First Name: Craig
- Last Name: Raynor
I sold my 15 Canadian touring and now the rest of the collection, moving soon and priced to sell. Sliding gear transmission , complete 15 rear axle with original “matching “ring and pinion , 7-3-15 complete engine block with crank unit (free spinning) , low head and aluminum hogs head - no tea cup pan or transmission. Hogs head set up for electric starter , usable early front axle with good spring perches, earl four screw brass top coils, 15 forked electric head lights with forks, 16 and up engine pan , early front radius rods with 1.25 diameter round balls , 3 -30”x 3 1/2” wheel one has the correct front hip for a 15 speedometer, Best-o- lite empty acetylene tank, front and rear early tapered springs , round gas tank with mounting brackets and assorted rear radius rods, as well as other front end rods, 1915 steering tube with quadrant also has the correct tube for horn wire attached,Holly G rebuilt and tested by Stan Howe … I will also have some non T related early fire equipment one interesting Item is a rotary gong … Call or text 631-905-4634 and I could email or send text pictures and we will work out a fair price.With my Technology challenged self I don’t seem to be able to load much on here
- First Name: Craig
- Last Name: Raynor
- First Name: Craig
- Last Name: Raynor
- First Name: Brian
- Last Name: Healey
- * REQUIRED* Type and Year of Model Ts owned: 1919 touring, 1915 Canadian touring 1915 roadster boat tail speedster
Re: Packing the truck for Hershey, RCC 33&34
Is there engine block a Canadian block? If so I my be interested in that and the cowl lights if they are Canadian as well. Also have a 15 Canadian touring
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Brian, have an early low Canadian head, no script on it if interested, and will be at hershey, have a machined canadian block ready to build,23-4 area.
- First Name: Brian
- Last Name: Healey
Joe if I was to get another block I would want it to be a15 block. Thanks for offer though
- First Name: Rob
- Last Name: Chatten
How much for the brass top coils? And your location ?
