WTB 26/27 Transmission Tailshaft
1913Runabout
First Name: Brian
Last Name: Harlamoff
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Post by 1913Runabout » Fri Sep 30, 2022 8:54 pm
Looking for the driven plate / tail shaft for a 26/27 transmission. I have several, but the shaft OD where the 4th main cap goes are all mangled.
Note: this is the one that does not have a ridge where it connects to the brake drum by bolts. See photo. It measures 7 1/4" across the face.
Email me if you can help me out. Thanks
Brian
26 T speedster
13 T runabout
12 T touring.
1926 style
1926 style
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Re: WTB 26/27 Transmission Tailshaft
Post by Mark Gregush » Fri Sep 30, 2022 11:23 pm
If the shaft is tight to the drive plate and pin holes are good, get it turned down and polished then have Gene French bore a 4th to your size.
1920 Dodge touring
