Parts To Be At Hershey
Topic author - Posts: 13
- Last Name: Davis
15 striped trans pedals; '13 door hinge; '9-'12 dash brackets; speedster block, unfinished project, oversize valves, drilled crank, std. bore. See at Hershey spaces GDF 21-23. (Green Field)
- Last Name: Davis
Re: Parts To Be At Hershey
Following items to be at Hershey spaces GDF 21-23 ( Green Field)
Fifteen striped trans pedals; '13 door hinge; '9-'12 dash brackets; speedster block - unfinished project; oversize valves, drilled crank, std. bore
