Fully rebuilt Moore auxillary transmission FS
Posted: Sun Oct 30, 2022 3:48 pm
by m2m
For Info on Moore transmissions see the link below (but note that the shifter on mine is of a different design):
http://www.mtfca.com/discus/messages/118802/139700.html
Moore was possibly the 3rd most popular aux. trans after Ruckstell and Warford. Advantage over Ruckstell is that the Moore has a neutral (so you can have the T towed a long distance without fear) plus if you have an early rear end you don't lose that look. The Moore is rear mounted so no heavy weight hanging off the back of your engine/transmission like the Warford. And rear mounted means better weight distribution for speedsters.
I'm putting up for sale my never used (rebuilt about 5 years ago) Moore underdrive that comes complete with a shortened tube and a newly made shortened driveshaft. It was rebuilt my someone well known in antique Ford circles for his quality work. The gears are good and new parts were machined as part of the rebuild.
Price is $2000 and I have more in it than that. It's located in NW AR but I'm likely doing some travel soon and might be able to delivered it closer to you. It's too big and heavy to ship.
Re: Fully rebuilt Moore auxillary transmission FS
Posted: Sun Oct 30, 2022 3:58 pm
by m2m
I will take some photos in the next day or two.
Posted: Mon Oct 31, 2022 5:13 pm
by m2m
Here's some photos
Posted: Mon Oct 31, 2022 5:17 pm
by m2m
I can email more photos to anyone interested.
Posted: Mon Oct 31, 2022 6:01 pm
by 1913Runabout
Is that a stock Ford spool and Hyatte roller bearing?
Do you have the rest of the shift lever?
Brian
Santa Cruz CA
Posted: Mon Oct 31, 2022 8:32 pm
by Allan
The Moore transmission does use a standard spool and Hyatt bearing at the rear.
All that appears missing from the shifter is short length of water pipe. Mine is about 15" long, threaded on the end to take a screwing knob.
Posted: Mon Oct 31, 2022 8:55 pm
by Art M
What is the gear ratio. And is it underdrive and direct only and no overdrive. Just curious
Posted: Tue Nov 01, 2022 1:30 am
by m2m
Brian
Santa Cruz CA
As Allan mentioned, this version of the Moore didn't have a special shifter (unlike the one in the link at the top). A pipe or rod (cut to your desired length) with a knob on the top as all you need. You should easily be able to find something that works, maybe something similar to this:
https://www.summitracing.com/parts/upd- ... UYQAvD_BwE
Posted: Tue Nov 01, 2022 5:16 am
by Wayne Sheldon
Art M, The Moore was a sliding-dog shift with direct and 50 percent underdrive. In good condition, they are easy to shift, and although they do have a neutral, rarely miss or get stuck in neutral. However, it is possible to get stuck there, especially if one kills the engine mid-shift? And therefore good brakes of some sort not relying on the driveline are a necessity. Same with a Ruckstell.
I wish I could afford this. They were one of the earliest auxiliary transmissions for a model T. And allow a good mountain intermediate gear for brass era model Ts.
Posted: Tue Nov 01, 2022 7:32 am
by m2m
another pic of rebuild
Posted: Tue Nov 01, 2022 7:44 am
by m2m
another pic
Posted: Tue Nov 01, 2022 7:46 am
by m2m
another pic
Posted: Tue Nov 01, 2022 7:48 am
by m2m
another pic
Posted: Tue Nov 01, 2022 9:11 am
by Tim Rogers
Wasn't aware that Ruckstell made an auxiliary transmission, just the 2-speed axle- learn something new every day.
Anyone have a picture of one?
Posted: Wed Nov 02, 2022 1:31 pm
by Dan Hatch
Email sent. Thanks Dan
Posted: Tue Nov 22, 2022 12:53 pm
by m2m
Still available. Please note that the transmission is now in storage in Kansas (I moved it from Arkansas).
Posted: Sun Jan 08, 2023 7:55 am
by m2m
Still available. I've had some interest but distance from potential buyers seems to be the problem as it's not something that can be shipped easily. There's a chance I might be able to get it to Chickasha Pre-War Swap Meet.
Posted: Wed Feb 08, 2023 7:09 pm
by m2m
Still available.
Posted: Wed Feb 08, 2023 9:15 pm
by Poppie
Good one Tim.....n
Posted: Sun Mar 19, 2023 1:06 pm
by moddamatt
Hello, do you happen to have any measurements or detailed drawings/pictures of the rear section? I know it uses stock model t parts but I need a better look at the rear plate that bolts to the T rear end.
