Brass Holley G carburetor
Posted: Mon Oct 31, 2022 5:33 pm
Probably an earlier one, 1915, because it came with hex head idle screws, all brass drain plug and spray needle. Completely disassembled and cleaned, new float, venturi, choke spring, reconditioned spray needle, float valve and test run. $195 plus $17.05 shipping. I didn’t bend the choke staple yet because if you want a double choke arm for a starter I can put one there instead. Email: wlkma9@gmail.com
