Prest-O-Lite tank and regulator F/S
Posted: Thu Apr 25, 2019 5:05 pm
This is a 4" diameter type MC ( motorcycle) tank with regulator and flow control needle valve. If you want to leave the generator on the running board and still burn your gas lamps then this is a great way to go. Fits easily under the rear seat of a touring or in a larger tool box.
