‘13 (I believe) windshield hinges
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sun Nov 20, 2022 10:42 pm
Here is a set of ‘13 (I believe) windshield hinges. My absent minded dad cleaned up and painted these hinges for his ‘15, only to find out that they do not align the windshield panels inline with one another as a ‘15 requires. I suspect these are for ‘13 as the encyclopedia shows ‘12 would have been brass, and ‘14 folds to the rear. There are a couple of stamping tears in the corners, otherwise no cracks, rust pits, damage, or noticeable wear.
I’m no year expert so please review pictures carefully. $100 shipping included in the lower 48
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Re: ‘13 (I believe) windshield hinges
Post by KWTownsend » Mon Nov 21, 2022 12:50 am
Kevin,
I believe those are 1914 windshield hinges.
I know some (maybe not all?) 1913 hinges have a rounded (think very small hockey puck) shaped cover.
Nice hinges, by the way.
Keith
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Nov 21, 2022 11:32 am
Thanks for the feedback Keith! The last thing I want to do is misrepresent these hinges, so appreciate your perspective.
I ruled out ‘14, as the pivot would need to be offset toward the rear to allow rearward folding. These hinges do not allow the necessary range of travel when oriented in this way, hence my assumption of ‘13. Here is a pic of the hinge in the last detent “fully open” before the arms bind. Nearly inline (close enough to fool my dad 😉)
Here is a pic from the side (also showing one of the stamping flaws)
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: ‘14 (verified) windshield hinges
Post by Kevin Pharis » Mon Nov 21, 2022 11:51 am
I should have never doubted you Keith! A little searching shows that the ‘13 hinge is a dramatically different design, and the ‘14 is definitely what I have here. Here is a link to an old post discussing the ‘14 hinges;
viewtopic.php?f=5&t=5772&p=43847&hilit= ... nge#p43847
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Nov 21, 2022 12:30 pm
1914 w.s. hinges are the only ones with the "double" bump detents.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Nov 21, 2022 9:53 pm
I should probably thank you twice Steve… you were the one that identified the hinges in the linked thread👍
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Fri Nov 25, 2022 12:47 pm
Black Friday bump to the top
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: ‘14 windshield hinges
Post by Kevin Pharis » Sun Dec 04, 2022 3:52 pm
How about $75 for these nice ‘14 windshield hinges…?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Dec 10, 2022 7:18 pm
To the top
Post by Scott_Conger » Sat Dec 10, 2022 8:02 pm
Kevin
change your title to '14, and broaden your audience to those seeking '14 hinges...
NH Full Flow Float Valves
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
MTFCA Number: 21848
MTFCI Number: 22173
Post by rickd » Mon Dec 12, 2022 8:41 am
Kevin, I will take the 14 hinges. Just emailed you through this site with my address info. Thanks.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Dec 12, 2022 7:49 pm
Sold! Thanks MTFCA!
