WTB Small Drum Rear End
Topic author - Posts: 1708
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
I am helping an 87-year-old new Model T owner get his 1920 coupe drivable, and the rear end is shot. Wheels were loose and now the axle taper, keyway, and hubs are wallerd out, spring perches are almost worn thru, rear springs are wrong, and who knows what else is bad. I will help him rebuild it but I would prefer to spend my time on a better core. Located in Northern Michigan in Charlevoix. Personally, I would wait for an auction or swap meet, but the owner is 87 and time is of the essence.
- First Name: Al
- Last Name: Haines
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring. 1924 Roadster
- MTFCA Number: 51396
Re: WTB Small Drum Rear End
Hi, email sent
I have several small drum axle housings, some ring & pinion gears, a used differential housing, some axle gears (1 NORS). Also Hyatts with loose cages with their matching sleeves. No spider or spider gears or axle shafts. But distance matters so .... just thought I'd mention it. Part swap/trade is possible. Your 11 hours away and its winter....uggg!
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Jeff, I just pulled the innards out of a 26 rear axle that I had rebuilt ten years ago and never used it, went to a ruckstel last week so I needed one half of the rear axle and driveshaft, I do have plenty of cases and an extra driveshaft.
- First Name: Tom
- Last Name: Strickling
- * REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 snowmpbile Staude and Shaw tractor conversions, Model T powered sickel bar mower
Jeff if you are coming to New Philadelphia, you could stop at joes on the way
- Last Name: Humble
Thanks for the replies. My preference would be to find a rebuildable core in northern Michigan, if none are available I can travel farther but this time of year it is not so desirable to do so.
- First Name: William
- Last Name: Schubert
- * REQUIRED* Type and Year of Model Ts owned: 1920 Runabout, 1920 Touring, 1925 TT
- MTFCA Number: 22318
- MTFCI Number: 18853
Jeff if you are heading south as far as Bay City, I should be able to help you out. I have housings, axles and differentials just a little short on bearings. I can do some digging to check on perches and hubs if necessary.
Bill Schubert
Bill Schubert
