WTB 1914 Bolts for Bracket to firewall.
Posted: Sat Jan 28, 2023 1:30 pm
by Brian D
Looking for all 6 correct carriage bolts for my 1914 Touring, the ones from the bracket to firewall.
They have a high dome heads.
They are 5/16.
The graph paper is 1/4.
The holes do lineup it was how I was holding with one hand and taking photo with other.
Brian
586 864 5110.
Re: WTB 1914 Bolts for Bracket to firewall.
Posted: Mon Jan 30, 2023 8:26 am
by Brian D
Also all four for steering column to firewall.
Thank you,
Brian
Posted: Mon Jan 30, 2023 9:48 am
I’m sure you might know this but an alternative is use a carriage bolt and reshape the head a little to make it look like an original. If you go to an older farm or dealership store they might have some non-plated bolts you can use.
One of the T suppliers use to have some correct carriage bolts they would sell. Maybe they still do.
Posted: Mon Jan 30, 2023 10:41 am
I have a friend who is having the same problem. I'm not sure if the bolt you have pictured is correct. From what I've been able to find out the head diameter is 13/16. Ford bolts appear to be a cross between a carriage bolt and a step bolt.
Posted: Mon Jan 30, 2023 10:45 am
by Dan Hatch
Aren’t they pictured in Gail’s book. I will check later today.
Posted: Tue Jan 31, 2023 11:40 am
Some of Gail's research is in the latest Model T Judging Guidelines, and I believe when I was reading it recently it says the heads are 13/16".
