Early Stevens T-122 Drve Shaft Sleeve Puller
Posted: Sat Feb 11, 2023 9:46 am
This is a less common example of the Stevens, NY T-122 drive shaft roller bearing sleeve remover. This version has a cast iron body and uses two steel half moon clamshell pieces to capture the sleeve while pulling it off the end of the drive shaft. Later pullers were made entirely of steel and used a different capture mechanism. This tool was included as part of the Stevens Drive Shaft Overhaul tool kit. We would suggest using a worm gear hose clamp around the steel half moon pieces to keep them from slipping off the drive shaft sleeve. The puller is in good condition. $300 plus shipping.
