On Craigslist 1926/27 motor and 2 trans
Autie
First Name: Keith
Last Name: Keller
Post by Autie » Sun May 05, 2019 3:17 pm
This is posted on central MI Craigslist. I have no connection to the seller. Whenever I find post that might help out others, I pass it along. It is listed as a 1916, but the trans/hogshead are clearly a 1926/27. Doesn't look too bad. I noticed three valves have been replaced at some point. The hogshead has the mounting tabs that bolt to the rear of the block. He is asking $600. Here is the actual post....." 1916 Model T Engine for Restoration. Engine is in good condition. Will need intake and exhaust manifold. I may have a carb that will fit this engine. The carb will need rebuilt. Engine will need gaskets/seals. It comes with vintage engine stand shown in picture. Two transmissions and mag plates. Transmission top housing with pedals."
You may call and leave a message at 517 227 4453. I will return you message ASAP. Please leave a message. Or email me through Craig List.
Cash Only."..................My computer skills suck and I don't know how to link the add onto this post. Hope this helps someone out
Re: On Craigslist 1926/27 motor and 2 trans
Post by Scott_Conger » Sun May 05, 2019 4:38 pm
if you will place the cursor over the original link and right click it and chose "copy" then open a dialogue box on the forum and right click the mouse again and chose "paste", it will be there. Other ways to do it, but this is pretty easy to explain
I suspect this is what you found: https://centralmich.craigslist.org/pts/ ... 81448.html
I should be able to recall, but this appears to be one of the last 15,xxx,xxx engines made. You're right, it certainly is not 1916, but it is what it is.
