SOLD- FS Ruckstell Large Drum Rebuilt Rear Axle Assembly
Posted: Wed Mar 08, 2023 7:49 pm
o Fully rebuilt Ruckstell large drum rear axle assembly including a Ruckstell center shifter & control rod, relined emergency brake shoes with rods & and supports – painted gloss black – full assembly ready to install.
o The total rebuild included all NEW: standard ring & pinion, axle shafts, hardened bearing sleeves, inner and outer modern seals, bushings, shims, thrust washer, drive shaft & bushing, modern pinion bearing, shift lock assembly, emergency brake cams & bushings, emergency brake shoes with hand brake rods & and supports.
o Full disassembly, cleaned, inspected, repaired as needed, then professionally reassembled with high quality parts. Then a quality high gloss black paint was applied. This is a full high quality Ruckstell rear axle assembly!
o Complete build sheet of parts & cost upon request. Must pick up. Can be delivered to Chickasha. $3850 - Changed price due to typo. Email me at markpaulagember AT aol dot com[
SOLD
SOLD
