How to Unstrangle your Kingston L-4... The New Kingston Super Valve - sold out
Posted: Thu Mar 09, 2023 1:32 pm
by Scott_Conger
Once I have gaskets in hand, I will have 10 of these Super Valves available for purchase. These may be the first of many or the last of a few, depending on response.
Improvements over the stock valve are as follows:
  • throughput is massively greater than a stock valve
  • has a superior Viton tip to seal far better than traditional steel tips
  • cannot get stuck closed, as there is a hook which will be acted upon by the float to ensure complete, on-demand flow
Contact me via email only...no PM's please...
Original design vs Super Valve - With Enhanced Flow Characteristics
Re: How to Unstrangle your Kingston L-4... The New Kingston Super Valve
Posted: Thu Mar 09, 2023 3:58 pm
by South park zephyr
I will take one
Scott Francis
Re: How to Unstrangle your Kingston L-4... The New Kingston Super Valve - just a few left
Posted: Fri Mar 10, 2023 11:18 am
by Scott_Conger
Only a few left
Posted: Fri Mar 10, 2023 2:24 pm
by Bryant
email sent.
Bryant
Posted: Fri Mar 10, 2023 7:11 pm
by Franko
I would also like to have one ! Tim Franko
Posted: Fri Mar 10, 2023 7:27 pm
by Bruce Compton
Great idea Scott. That little hook will sure eliminate the fairly common problem of the viton tip sticking in the seat. Ford even used a similar device to insure complete opening of that passage in the 60's with a steel needle and brass seat.
Re: How to Unstrangle your Kingston L-4... The New Kingston Super Valve - sold out
Posted: Fri Mar 10, 2023 7:45 pm
by Scott_Conger
All gone
thank you very much
