Re-babbitted ball cap ( 4th. main )
Posted: Fri Mar 24, 2023 11:03 am
by Gene_French
Model T ball cap re-babbitted and bored to Standard or you specified diameter ...price is $50.00 + exchange + $19.30 priority flat rate mail in lower 48 states or actual postage outside this area or INTERNATIONAL ...Gene French 970-581-2808 or
gfrench1953@hotmail.com
Re: Re-babbitted ball cap ( 4th. main )
Posted: Sun Apr 02, 2023 11:02 am
by Gene_French
to the top again ...thanks MTFCA
Posted: Sun Apr 02, 2023 2:24 pm
by Nv Bob
Gene
I been digging have two so far and befor I send them got one more pile to dig on
Nv bob
Posted: Thu Apr 06, 2023 11:41 am
by Gene_French
Bob:
thanks for looking ... if you can send a batch that cuts down on the mailing cost per item ... always an optimist Gene French
Posted: Sat May 13, 2023 9:40 am
by Gene_French
Posted: Sun Jul 02, 2023 10:10 am
by Gene_French
Posted: Sat Oct 14, 2023 3:16 pm
by Gene_French
Posted: Sat Oct 14, 2023 3:24 pm
by Tim D
Do you buy bad ones for cores?
Posted: Fri Dec 01, 2023 10:21 pm
by Gene_French
Posted: Thu Jan 18, 2024 10:03 am
by Gene_French
Posted: Thu Mar 28, 2024 10:06 am
by Gene_French
to the top again ... thanks MTFCA
Posted: Sun Aug 04, 2024 9:12 am
by Gene_French
Posted: Thu Aug 29, 2024 9:25 am
by Gene_French
Posted: Sat Jan 04, 2025 10:59 am
by Gene_French
Posted: Sun Jan 05, 2025 12:50 am
by Shrshot
Gene I need to replace my 4th main ball cap. Where should I take the measurement to determine if I need std. or .002 under? I pulled the rear axle assembly, and have quite a bit of oil in the torque tube leaking from the ball cap. Have to repair/rebuild rear diff as spool housing is cracked and leaking grease also. Oh the joys....
Posted: Sun Jan 05, 2025 10:41 am
by Gene_French
Kent:
you will measure the clutch plate ... probably with a dial or vernier caliper ... with the ball cap removed you will reach into the hogs head with the caliper jaws and measure the outside diameter of the clutch plate tailshaft ...access is difficult with anything except a long jaw caliper or the removal of the hogshead ...
Posted: Mon Jan 06, 2025 1:16 pm
by Shrshot
Thanks Gene, I will get ahold of you when I get the ball cap out and shaft measured.
Posted: Sun Jan 26, 2025 10:57 am
by Gene_French
Posted: Fri Apr 18, 2025 8:43 am
by Gene_French
Posted: Fri May 30, 2025 10:02 am
by Gene_French
to the top again ...Thanks MTFCA
Posted: Sat Jul 05, 2025 8:35 am
by Gene_French
Posted: Sat Nov 08, 2025 8:34 am
by Gene_French
Posted: Mon Dec 29, 2025 8:58 am
by Gene_French
