Front cover centering gage
Topic author - Posts: 829
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
front timing cover centering gage … this is the tool used to center the timer recess to assure uniform timing from cylinder to cylinder … this is often overlooked when re-assembling an engine and a poorly centered timer will result in poor performance … this tool centers the actual timer recess to the camshaft ...NOT the much smaller design that centers the seal recess … price is $30.00 plus $7.50 postage in lower 48 states ...actual postage outside this area or international ...Gene French 49519 cr.23 Nunn,Co. 80648 phone 970-581-2808
- First Name: Gene
- Last Name: French
Re: Front cover centering gage
to the top again ...thanks MTFCA
- First Name: Gene
- Last Name: French
- First Name: Patrick
- Last Name: Goodman
- * REQUIRED* Type and Year of Model Ts owned: 1919 Runabout 1925 touring
- Board Member Since: 2022
Great tools!
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
- First Name: Gene
- Last Name: French
