Zero Maintenance Timer
Posted: Sat Mar 25, 2023 11:43 am
Tired of messy timer maintenance every 500 Miles? Surging, jerking, missing....
An Ideal Timer is completely maintenance Free and direct drop in replacement for the stock mechanical timer. Start on battery and run on Magneto, the I-Timer is immune to timing cover misalignment and provides reliable coil activation precisely synchronized with piston position at any engine speed without roller skip, wiper bounce, contact wear, arcing or other flaws associated with mechanical timers.
Simply replace your mechanical timer with the I-Timer and enjoy smooth, optimal engine performance at any engine speed with properly adjusted stock Model T coils.
More information about the I-Timer here: www.modeltitimer.com
