Tire Pump SOLD
Posted: Wed May 03, 2023 9:22 pm
Model T era single brass tube hand operated tire pump. Base is cast iron and is marked Ford. Tube is free of dings, but has obvious wear signs…must have been riding under the seat or in the turtle deck for years. It does compress air, but there is a new air hose, but no nozzle to attach to the tube valve stem – the thingamajig that screws onto the valve stem. (A rebuilding kit is available from Lang’s and others, if you plan on using it to inflate the tires). $55.00 plus shipping to your place.
