Steering column fs. Sold
Posted: Fri May 12, 2023 12:02 pm
by CTLeonard
Believe this to be the 13-15 era. Teeth on quadrant are worn. 270.00 plus shipping.
ctleonard64@gmail.com
Re: Steering column fs
Posted: Fri May 12, 2023 9:12 pm
by Bill Everett
With that firewall mounting plate, I think it may be for a '12.
Posted: Fri May 12, 2023 10:26 pm
by Tbird
Offset hole definitely a 12 feature, has square holes instead of round and the flattened control rods which were 13 features. Would be interesting to see the control rods if they have the checkered pattern. I’m guessing late 12 early 13.
Posted: Sat May 13, 2023 8:49 am
by TWrenn
Tbird wrote: ↑Fri May 12, 2023 10:26 pm
'13 also had the offset bolt hole. Sadly, and probly no one will ever know exactly when, the change was made from not only the hard rubber ends of the handles to the flattened style, as well as switching from the cast flange to pressed steel. My April 22 '13 has the steel flange FWIW.
