Metzger
Posted: Thu May 18, 2023 6:23 pm
by GOLDBARBILL
OK. I have my windshield assembly, support rods, and found some new springs. Now I need glass. What do i need for this: channel material, glass clamps, rubber or felt for wind and rain protection? And does anybody know of a source of the actual glass in or around Seattle? Bill Conner
Re: Metzger
Posted: Thu May 18, 2023 8:08 pm
This the classified section. You'll get more help by asking your questions in the forum.
https://www.mtfca.com/phpBB3/viewforum.php?f=2
Re: Metzger
Posted: Thu May 18, 2023 8:47 pm
by RGould1910
Im assuming you have a Mezger "Automatic" windshield used on 1909 and some 1910 Model Ts. You need brass setting channel. It's the same stuff Speedway Motors makes but the corner radii are different than those for their repro windshields. Langs has the dies and will make them up for you if you give them the dimensions and the corner radius.. The frames take 3/16"glass. Make some patterns from Masonite for the glass cutter. Good luck.
