Wanted to Buy - Rear Budd Wire Wheel Hubs and Hubcap Wrench
Posted: Fri May 19, 2023 5:40 pm
by David Greenlees
Wanted: Budd T Ford left and right rear hubs in usable or restorable condition, the hub caps are not needed but will purchase for spares. The outer end of the hub which is threaded inside is 1-23/32" or 1.718" on the outside diameter
and 1.275" or 7mm on the inside diameter. The OD of the hub cap threads is 1-11/32" or 1.344.
- budd wire wheel wrench.jpeg (16.36 KiB) Viewed 1276 times
Wanted: Budd 1-7/8" wrench wire wheel in usable condition.
Photo courtesy of Dan McEachern.
Email at the contact link below my name and location. OR call or text @ eight-O-two-four-nine-O-six-five-O-nine
Re: Wanted to Buy - Rear Budd Wire Wheel Hubs and Hubcap Wrench
Posted: Sat May 20, 2023 12:05 am
by frontyboy
I have a real Budd wheel wrench, extra to me, also have a rare Budd rear wheel carrier bracket, This is a factory unit using a front hub as the wheel mount. This attaches to the rear cross member with a goose neck shape.
Both are forsale
frontyboy2oh6-919-1949(Seattle) text or call.
Posted: Mon May 22, 2023 4:12 am
by Monmarte
frontyboy wrote: ↑Sat May 20, 2023 12:05 am
Both are forsale
G Switch
In the past I used to buy a lot of parts from scrap yards to get them at affordable prices. But it's different now, with parts and tools like this that can't be found in the dump.
Posted: Tue May 30, 2023 8:21 pm
by Southfork Creek
Hi David, The rear Budd hubs I have are not Model T. Rollie
