WTB: Bittner voltage regulator.
Posted: Mon May 22, 2023 12:18 am
by frontyboy
Still looking for a Bittner voltage regulator. This was used in conjunction with the Bittler electronic coil system. New or used, still looking.!!!!
thnx,
frontyboy, call or text 2oh6-919-1949(Seattle)
Re: WTB: Bittner voltage regulator.
Posted: Tue May 23, 2023 2:34 pm
by J1MGOLDEN
Snyders was selling them a year or so ago.
I have one that does not work and is sealed in plastic, so I cannot repair it.
Posted: Tue May 23, 2023 2:39 pm
by J1MGOLDEN
Many of Bittner's TrueFire system got a bad rap because you had to have a good battery and the correct 1/0 or 0 Gauge Battery cables to get 5 volts or a little more at the starter terminal while cranking.
The heart of the system was a 12 Volt Ford coil set and the box had a voltage doubler inside to turn 6 volts into 12 volts.
The TrueFire coils needed about 11.5 Volts to properly operate.
You did not really need that voltage regulator at all.
