Wanted Chicago trans case
Posted: Wed May 24, 2023 11:21 am
by t-time
Going through a Chicago transmission and discovered the case has been welded. I would rather not use it so I'm looking for another.
Re: Wanted Chicago trans case
Posted: Wed May 24, 2023 1:20 pm
by Michael Peternell
There are two different Chicago cases. One says patent pending the other does not. Different bearings between the two. I've got one you can have for the cost of postage. Might get a little spendy MN to CA. You can let me know if you can't find one closer.
Mike Peternell
Posted: Wed May 24, 2023 5:27 pm
by t-time
This one has patent pending in the casting. Thank you
Posted: Mon Jun 05, 2023 2:27 pm
by t-time
A case has been located. thanks to everyone who responded.
Posted: Mon Jun 05, 2023 7:08 pm
by TeveS-Nor Cal
Have you opened it?
Posted: Tue Jun 06, 2023 9:21 am
by t-time
I have, I've seen worse. I'll start with evaporust and see what it will do. Thanks again.
