1925 block
Topic author - Posts: 3298
- MTFCA Number: 121
- MTFCI Number: 16310
1925 block
I would like to buy a good 1925 block with a 12,000,000 serial number.
- First Name: Mike
- Last Name: Leonard
- * REQUIRED* Type and Year of Model Ts owned: 6
Re: 1925 block
I have one in Mt. Vernon in. It's a 1187xxxx which makes it a June baby. Have no idea of condition. The price is right though. Email for photos. Thank you. ctleonard64@gmail.com
- First Name: Mike
Re: 1925 block
Discovered I also have an 11602xxx that's in better shape appearance wise. ctleonard64@gmail.com
- First Name: Kim
- Last Name: Dobbins
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring, 1910 touring, 1913 touring, 1916 couplet, 1924 truck.
- MTFCA Number: 8243
Re: 1925 block
Larry, check with Bill Bennet, he has one.
- MTFCA Number: 14383
Re: 1925 block
Why not get any 23-25 single valve door motor & make it into your 25, with your motor #?
- MTFCA Number: 121
Re: 1925 block
No John, that is not the way things are done!
- First Name: Adam
- Last Name: Doleshal
- MTFCA Number: 23809
- MTFCI Number: 1
Re: 1925 block
No way to tell for sure that any particular block hasn’t had that done already anyway…
- MTFCA Number: 24868
Re: 1925 block
A little harder. I think the hardest thing is to find an exact matching # stamp set.Jerry VanOoteghem wrote: ↑Fri Jun 02, 2023 6:33 pmWouldn't casting dates be harder to fake/modify than serial numbers?
Casting date marking can be copied from the original block with a silicone mold & reset on the new block with JB weld. Paint to cover.
Re: 1925 block
You know, the legal profession has a term for all or part of this, and it isn't "clever".
NH Full Flow Float Valves
- First Name: Rich
- Last Name: Chillingworth
- * REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
- MTFCA Number: 30527
- MTFCI Number: 23207
Re: 1925 block
I have several 1926 style blocks with 1925 serial numbers available. I'm already half way to California to visit family and attend the Auburn swap meet.
Rich C.
Rich C.
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
Re: 1925 block
The 1924 and 1925 T blocks are the same and there is no casting date on them, the 1923 T block is different as it has the Ford script on the side and a slightly different shape number pad. A 1925 number beginning with 12 million will be a little harder to find because the 1926 style engines started at the 12.2 million range.
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
Re: 1925 block
Original was very specific with what he wants.
Don't try to confuse him with facts.
- First Name: Jim
- Last Name: Davis
- MTFCA Number: 49832
- MTFCI Number: 24686
Re: 1925 block
Don't make Larry blow a fuse!
