1925 block
Posted: Thu Jun 01, 2023 11:15 am
by Original Smith
I would like to buy a good 1925 block with a 12,000,000 serial number.
Re: 1925 block
Posted: Thu Jun 01, 2023 2:35 pm
by CTLeonard
I have one in Mt. Vernon in. It's a 1187xxxx which makes it a June baby. Have no idea of condition. The price is right though. Email for photos. Thank you. ctleonard64@gmail.com
Re: 1925 block
Posted: Thu Jun 01, 2023 2:51 pm
by CTLeonard
Discovered I also have an 11602xxx that's in better shape appearance wise. ctleonard64@gmail.com
Re: 1925 block
Posted: Thu Jun 01, 2023 7:09 pm
by KimDobbins
Larry, check with Bill Bennet, he has one.
Re: 1925 block
Posted: Thu Jun 01, 2023 8:07 pm
by speedytinc
Why not get any 23-25 single valve door motor & make it into your 25, with your motor #?
Re: 1925 block
Posted: Fri Jun 02, 2023 11:28 am
by Original Smith
No John, that is not the way things are done!
Re: 1925 block
Posted: Fri Jun 02, 2023 6:27 pm
by Adam
No way to tell for sure that any particular block hasn’t had that done already anyway…
Re: 1925 block
Posted: Fri Jun 02, 2023 6:33 pm
by Jerry VanOoteghem
Wouldn't casting dates be harder to fake/modify than serial numbers?
Re: 1925 block
Posted: Fri Jun 02, 2023 6:50 pm
by speedytinc
A little harder. I think the hardest thing is to find an exact matching # stamp set.
Casting date marking can be copied from the original block with a silicone mold & reset on the new block with JB weld. Paint to cover.
Re: 1925 block
Posted: Fri Jun 02, 2023 7:56 pm
by Scott_Conger
You know, the legal profession has a term for all or part of this, and it isn't "clever".
Re: 1925 block
Posted: Fri Jun 02, 2023 8:26 pm
by richc
I have several 1926 style blocks with 1925 serial numbers available. I'm already half way to California to visit family and attend the Auburn swap meet.
Rich C.
Re: 1925 block
Posted: Sat Jun 03, 2023 1:31 am
by kmatt2
The 1924 and 1925 T blocks are the same and there is no casting date on them, the 1923 T block is different as it has the Ford script on the side and a slightly different shape number pad. A 1925 number beginning with 12 million will be a little harder to find because the 1926 style engines started at the 12.2 million range.
Re: 1925 block
Posted: Sun Jun 04, 2023 11:50 am
by J1MGOLDEN
Original was very specific with what he wants.
Don't try to confuse him with facts.
Re: 1925 block
Posted: Sun Jun 04, 2023 12:21 pm
by Novice
Don't make Larry blow a fuse!
