FS - left side mount belt drive alternator
Posted: Mon Jun 26, 2023 6:31 pm
by t-time
New 12 volt alternator kit for 09-27 for model T. Simple bolt on installation, no modifications to engine required. Mounts on the left water outlet neck bolt using a special included bolt, tension bracket uses two of the block to pan bolts. 12 volt, 30 amp, negative ground mini Denso style alternator has a flat belt pulley. Requires a longer belt (not included). 2 wire hook up - positive to ammeter, ignition on switched positive.
Re: FS - left side mount belt drive alternator
Posted: Wed Jun 28, 2023 2:16 pm
by Nikko012
Is this your design. I am interested.thanks ray
Posted: Wed Jun 28, 2023 3:25 pm
by t-time
It is, I needed something on my speedster so I came up with this.
Posted: Wed Jun 28, 2023 7:06 pm
Nice design - was also wondering the same !
Posted: Tue Jul 04, 2023 5:50 pm
by DOBSONN
Hi Mark, I would be keen to purchase one - are you able to ship internationally to New Zealand.
Posted: Wed Jul 05, 2023 9:06 am
by Quickm007
Hi Mark, Interested to get one for my speedster either. I have USA address as well. mario dot brossard at sympatico dot ca
Posted: Thu Jul 13, 2023 1:04 pm
by t-time
back to the top
Posted: Fri Jul 14, 2023 2:15 pm
by Wayne Mims
I too, would be interested in one or two of them email address EWM 1948@yahoo.com or phone 512-995-6013 Wayne Mims
Posted: Sat Jul 15, 2023 12:07 pm
by Sarikatime
Birdhaven sells the complete setup, no brainer installation. Just thinking out loud.
Posted: Sat Jul 15, 2023 2:05 pm
by t-time
This is also a no brainer install and does not use head bolts for mounting, plus the alternator is smaller than the delco unit. The only part not in the kit is a longer belt. Just explaining out loud.
Posted: Mon Jul 17, 2023 6:53 pm
by Randall strickland
Heres the same I came up with 7-8 years ago!
Posted: Tue Jul 18, 2023 12:50 pm
by t-time
Great minds think alike!
6 volt version in the works.
Posted: Mon Jul 31, 2023 9:40 am
by t-time
back to the top
Posted: Sat Nov 18, 2023 5:57 pm
by t-time
6 volt version now available. https://www.ebay.com/itm/266502857774
Posted: Sun Nov 19, 2023 6:26 pm
by WillsT
Ordered 12 volt version from EBay, very good price
Excellent product and mounting hardware, simple to install
It is a 2 wire compact alternator, one wire for battery positive, one for switch on position
For my 1915 needed a 34” belt.
