FS KMC MANIFOLD
Posted: Tue Aug 08, 2023 1:32 pm
by Mark Chaffin
Neat accessory intake / exhaust manifold. Yours for $50 plus domestic shipping. Mark Chaffin (951) 805-0928
Re: FS KMC MANIFOLD
Posted: Tue Aug 08, 2023 2:27 pm
by DustySpokes
OK - I gotta ask this question, what else is needed to make this setup fully complete ? Me thinks there is a special little Kerosene tank as this setup is meant to be able to run kerosene as well as gasoline. ( I am pretty sure that I have a New Old Stock KMC brass carb , but not sure if it is the same model ) . -Dusty
Re: FS KMC MANIFOLD
Posted: Tue Aug 08, 2023 3:39 pm
by Mark Chaffin
I believe the tank is all. Everything else is there.
Re: FS KMC MANIFOLD
Posted: Tue Aug 08, 2023 5:05 pm
by Tourabout
I had one in the original wooden crate. It had a small gas tank to get the Model T started before switching it over to kerosene. It also had a 1/8” steel spacer shaped like a head gasket that you placed between two head gaskets to lessen the compression in order to run on kerosene.
Re: FS KMC MANIFOLD
Posted: Tue Aug 08, 2023 5:34 pm
by Mark Chaffin
Thanks for the additional info. Personally, I would probably remove the carburetor and add a regular updraft carburetor.
Re: FS KMC MANIFOLD
Posted: Tue Aug 29, 2023 1:44 pm
by DustySpokes
I have a New Old Stock, never used KMC carb that I would sell to someone who would want to have a very interesting accessory. I can let it go for $130
This is likely THE most elusive carbs you would ever find. With the purchase of Mark's setup , you would be in great shape with spare parts. -Dusty
Re: FS KMC MANIFOLD
Posted: Tue Aug 29, 2023 2:51 pm
by TXGOAT2
If only kerosene was still 6 cents a gallon...
Re: FS KMC MANIFOLD
Posted: Tue Aug 29, 2023 3:04 pm
by Dan Hatch
If only kerosene was still kerosene!
Re: FS KMC MANIFOLD
Posted: Tue Aug 29, 2023 9:29 pm
by TXGOAT2
It's denatured, like so much else.
Re: FS KMC MANIFOLD
Posted: Tue Aug 29, 2023 9:41 pm
by Mark Chaffin
My first wife had me denatured after our two girls were born.
