Mag Horn for sale Sold
Posted: Thu Aug 31, 2023 3:47 pm
by elliott1936
Magneto horn with mounting bracket. The horn is in need of a clean up. I think it works as It make a sound when I touched it to a 12 volt. Price is $75.00 plus the ride. Tom five03-644-937four. It appears to be in good shape with no dents.
Re: Mag Horn for sale
Posted: Thu Aug 31, 2023 9:17 pm
by JTT3
Tom might not be good for the horn to test it with a battery.
Best John
Posted: Fri Sep 01, 2023 10:13 am
Just touching it to 12 volts DC should not hurt it. It is just an electromagnet using AC that pulls the diaphram back then releases it 16 time per revolution of the flywheel. Checking it on DC would tell you that the windings are working when you hear the "clunk".
Posted: Sat Sep 02, 2023 12:46 pm
by Novice
If You have a old toy train transformer that should work to test it. adjustable voltage 0 to 24 volts a/c. 60 cycles
Posted: Sun Sep 03, 2023 7:34 pm
by elliott1936
Horn Has been Solded. Tom
