Sure Feed Oiling System For Sale Sold
Posted: Tue Sep 19, 2023 1:36 pm
by elliott1936
This is an original Sure Feed Oiling System for the model T. It can used with the two different ways to drain the oil from the hogs head cover into the front of the pan. It has the original fitting that bolts to the pan to engine bolts and drains the oil through one of the bolts that would hold the pan to the engine. The way that I used this until I went to a full pressure system, was a fitting that was bolted into the side of the pan. A drilled hole with a fitting that drained the oil into the front of the pan. $100.00 plus the postage.
Tom five03-644-937four twoelliott@msn.com
Re: Sure Feed Oiling System For Sale
Posted: Mon Jun 24, 2024 1:30 pm
by elliott1936
Repost this item for sale
Posted: Wed Aug 07, 2024 3:07 pm
by elliott1936
If you can use this item I will take an offer. Tom
Posted: Wed Aug 07, 2024 3:33 pm
by South Park Zephyr
Email sent
Posted: Thu Aug 08, 2024 3:31 pm
Check is in the mail
Thanks,
Scott
