Source for Split Rivets for Cowl on 26 coupe
Posted: Thu Sep 28, 2023 4:59 pm
by Ed Gallagher
Wanted: Source ideas on 1 inch split rivets to mount cowl lacing on 26 coupe
Re: Source for Split Rivets for Cowl on 26 coupe
Posted: Thu Sep 28, 2023 7:12 pm
by GG Gregory
I got mine from Lang’s
Posted: Thu Sep 28, 2023 8:13 pm
by Mark Gregush
Unless you are doing a points car, use pop rivets. You would almost need to take the tank out to set the ones on top, that are behind/above it. Think 1 inch would be too long anyway unless you are going to cut them back after pushing through. They would only need to go through and roll over like band rivets with tangs bent over on the outside and head on the inside.
Posted: Thu Sep 28, 2023 8:59 pm
by Allan
!/2" is long enough, but pop rivets are the go. Even on earlier steel firewall cars the two lower ones on each side I substitute with pop rivets, as you can't get to the back of them. On a show car you could solder the holes on pop rivets.
Posted: Thu Sep 28, 2023 9:05 pm
by Model T Matt
get aircraft rivets have nice smooth look when installed
Posted: Fri Sep 29, 2023 10:51 am
by jab35
Posted: Fri Sep 29, 2023 11:11 am
by Dan Hatch
Here is to help you get them facing them facing the right way.
http://www.mtfca.com/discus/messages/17 ... 1312905754
