Wanted True Fire Ignition Coil Box
Posted: Wed Oct 11, 2023 12:18 am
by JAGERK9
Im looking to replace my true fire ignition which I think has failed due to sitting for over 8 years. The creator of this has disappeared but I recall it worked great when I installed it 10 years ago. Thanks!
Re: Wanted True Fire Ignition Coil Box
Posted: Wed Oct 11, 2023 11:12 am
by Mark Gregush
I added a question to your Facebook post. With the plugs out, did you try cranking the engine over to check and see if the plugs were firing?
Posted: Wed Oct 11, 2023 2:36 pm
by CudaMan
Check with Lang's or Snyder's, they may have some new units still on the shelf.
Posted: Wed Oct 11, 2023 2:38 pm
by speedytinc
Hard to believe they go bad sitting.
Easier to believe a marginal electrical connection got worse.
Posted: Wed Oct 11, 2023 2:42 pm
by Fire_chief
Clean ALL the contacts. They don't work if there is any dirt or corrosion.
Posted: Wed Oct 11, 2023 7:17 pm
by Mark Gregush
It was a bad ground, he got it working.
Posted: Wed Oct 11, 2023 8:11 pm
by CudaMan
Excellent, thanks for providing closure! :)
Posted: Thu Oct 12, 2023 8:42 pm
by J1MGOLDEN
They don't go bad very often.
The real problem is the heart of the system is a Ford part used with 12 volt systems.
That box has a voltage doubler inside to make it work with the Ford part.
There has to be a good battery, battery cables, and starter switch to deliver 5 to 5.5 volts to the starter terminal while cranking the engine to give the box enough electricity to properly function.
With an analog meter with a dial, you have to measure the voltage between the starter terminal and engine ground while someone holds the starter switch down to determine the volage is adequate.
Another more dangerous test is to try cranking the engine with the key on.
The switching transistors in the timer cover do go bad and I have never found a replacement for them yet.
Posted: Sat Oct 14, 2023 8:05 pm
by J1MGOLDEN
I did make a TrueFire test set that will test the box and timer.
It is not very difficult to do, but most of the time the box is OK, if the fuse inside is not blown.
A big wing nut on the left turns the rotor and is not shown.
Posted: Sat Oct 14, 2023 8:07 pm
by J1MGOLDEN
The Test Set.
TrueFire Tester Top.JPG (47.59 KiB) Viewed 1950 times
Posted: Sun Sep 29, 2024 10:19 pm
by JAGERK9
Sorry for the very delayed response. You were correct there was nothing wrong with the True Fire box. My ground at the firewall showed grounded however the screw that went through the firewall was loose and not making contact on the brass tab on the other side of the firewall in the coil box. Once that got tightened she started like a new car.
Posted: Mon Sep 30, 2024 8:04 pm
by J1MGOLDEN
That little ground wire problem has failed frequently and given the TrueFire a bad name.
The other most common problems are a weak battery, a battery ground wire problem, or poor cables.
Measuring less than 5 Volts at the starter terminal with the engine being turned over is also a major problem.
Posted: Tue Oct 01, 2024 8:40 am
by TWrenn
If I might chime in here Jim, one other idiosyncracy (sp?) for TF is CLEANLINESS! Or lack thereof. After inheriting TF on my first Model T, which ran great with it I might add, after 2 years it started "acting up". Long story short, after 30 minutes of disconnecting everything and cleaning ALL the contacts it returned to its perfect performance. Subsequent TF's that I had proved the same. Cleanliness is next to Godliness!! :lol:
