(Sold) HCCT
Posted: Fri Oct 27, 2023 10:16 am
I bought this coil tester years ago and haven't done anything with it. It is in the same condition as when I bought it, except for the wood on the handle that was missing.The handle had already been welded. The coil that is in the tester is for display only and does NOT go with it! I have another tester just like this that I did restore, so it's time for this one to go!
I do not have the field coil, or the flywheel for it, and the meters would need to be repaired, but it turns free. I do believe that with repaired meters, the flywheel and field coil, it would work properly.
There is a person on the forum that advertised meter repair work.
Asking $400.00 plus shipping
