WANTED 1923 ENGINE BLOCK
Posted: Tue Dec 05, 2023 4:35 pm
by Stephen1915
Want to buy a 1923 Engine Block or complete engine. Must be 1923.
314-287-1901
Located in St.Louis Missouri
Re: WANTED 1923 Ford Title.
Posted: Tue Dec 05, 2023 7:58 pm
by Chris Haynes
When I need a title I simply go to the DMV and fill out an Application For Title and get one the right way.
Posted: Wed Dec 06, 2023 7:40 am
by Joe Bell
Some States is a whole lot harder to get one than others, Ohio you stole it till proved other ways and that is expensive!
Posted: Wed Dec 06, 2023 9:30 am
by Stephen1915
Still looking!
Re: WANTED 1923 ENGINE BLOCK
Posted: Wed Dec 06, 2023 2:37 pm
by Stephen1915
To the top
Posted: Wed Dec 06, 2023 2:44 pm
by Adam
Your ad says you want a block, but the headline on the first three responses say you want a title. Which is it?
I might be able to help if you are indeed looking for a 1923 block.
Posted: Wed Dec 06, 2023 3:31 pm
by Stephen1915
Adam, I have found out all I need is a block to obtain a title in my state. The car needs a complete engine anyway as it does not have one. Looking for a block or complete engine. Car is a low radiator steel firewall car, April-May-June build I would suspect.
Posted: Wed Dec 06, 2023 5:19 pm
by Adam
Stephen, I sent you an email.
Posted: Wed Dec 06, 2023 5:25 pm
by Joe Bell
I Have serial numbers that came off of blocks before they went to the foundry, you can stamp them on your block, free!
Posted: Wed Dec 06, 2023 11:01 pm
by Michael F
I am in west plains Mo south central I will check to see If I have a 23 block I have several blocks and engine and transmission parts ETC
Posted: Thu Dec 07, 2023 1:44 pm
by Stephen1915
Thank you guys!
Posted: Thu Dec 07, 2023 11:16 pm
by Michael F
I have checked and I have 17, 19 22, 24, 25, 26 Blocks but no 23 Sorry I cant help you
Posted: Fri Dec 08, 2023 4:22 pm
by pre15dale
Steven, I have a block, engine number 7555361 which puts it April 28, 1923 I believe. It's a bare block with main bearing caps and bolts. I also have most all parts to make a complete engine, will sell just the block or a package. reasonable
Posted: Fri Dec 08, 2023 4:44 pm
by Stephen1915
Dale, Thanks for the call.
