FS APCO 437 Spring Perch Removal Tool (SOLD)
Posted: Tue Dec 05, 2023 5:53 pm
Here is an original APCO T437 Spring Perch Removal Tool. This original Model T front axle perch remover utilizes 4 claws/clamps that go around the front axle, and the nipple threaded driver pushes on the dimpled threaded portion of the perch and drives it out. This tool was designed for mechanics of the time, for routine maintenance needs of perches in good condition, not 100 year old rust welded perches that are near impossible to remove. Perfect tool for that well maintained T, simply use to remove your perches to rebush or replace. Neat tool in good condition. 200 includes shipping.
